 Předmět příspěvku: 2012 Honda Gold Wing
 Příspěvek Napsal: 23 úno 2011 16:38
2012 Honda Gold Wing GL 1800 Technical Specifications
Model - Honda GL 1800
Engine type - 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke - 74 mm x 71 mm
Compression Ratio - 9.8 : 1
Valve Train - SOHC, two valve per cylinder
Induction - PGM-Fi
Ignition - Computer-controlled digital with 3-D mapping
Transmission - 5-speed including Overdrive and electric Reverse (standard)
Final Drive - Shaft
Front Suspension - 45mm cartridge fork with anti-dive system; 4.8 inches travel
Rear Suspension - Single ventilated 316mm disc with CBS three-piston caliper; optional ABS
Front brake - Dual full-floating 296mm discs with CBS three-piston calipers; optional ABS
Rear brake - Single ventilated 316mm disc with CBS three-piston caliper; optional ABS
Front tires - 130/70R-18
Rear tires - 180/60R-16
Wheelbase - 66.5 inches
Rake (Caster angle) - 29.15°
Trail - 109 mm (4.3 inches)
Seat Height - 39.1 inches
Fuel capacity - 6.7 gallons
Colors - Pearl White, Candy Red, Ultra Blue Metallic and Black
Curb Weight - 904 – 933 pounds, depending on the optional package
Honda Goldwing 1500 SE
skutrmoto.cz
